Will T30 standard springs stop rear sag on full conversion
Mike_L
Hi all 👋, Does anyone know if T30 springs are stiff enough to prevent rear sag on a fully converted T6? It’s currently lowered but I want it back to normal height for better clearance. It’s sitting level currently and I wish to keep it that way if possible. If so, does anyone have a set knocking about?? Thanks 🙏🏻
No... You will need T32 springs on the rear.
Assuming you have a T28?
That will support another 400kg more.
Have you been on a weigh bridge yet?
To see what your loads are?
Laiden,
Un laiden,
Front axle,
Rear axel,
Even T32 springs might not do the job - folk have experienced mixed results.
If you're going back to standard height then the Eibach rear levelling springs are designed specifically to counter the weight of a camper conversion and aren't expensive. RHQ have them in stock.
Laiden,
Un laiden,
Front axle,
Rear axel,
I have a T30 but it’s lowered, no idea what on though but it’s approx 50mm I reckon. It’s not been on a weigh bridge, no, but there’s one not too far away from me. Are the T32 springs direct fit on the back? I’m assuming I’d be ok to then get T32 springs on the rear and T30 on the front as I’ve read the front won’t fit directly without modification?
Thanks, I’ll take a look. I had heard these mentioned and so they sound like they’ll suit my requirements. Assuming I could then put the standard T30 springs in the front with the Eibachs on the rear?
Yes the T6 rear springs are a straight swap.
