Wireless reversing camera problem.
VWcamper2023
I have fitted a wireless reversing camera to the T6 back door, and ran the wires to the rear light cluster. I have also fitted the front receiver to my Road Angel head unit, All good.
I connected the Transmitter red wire to the Green/Black wire ( reversing light) and the black to the Brown ( negative ) of the rear light wiring. When I turn ignition on and put into reverse all works as should, and see the image on the head unit. The problem I have is if I start the van and put into reverse it does not work. I have checked and double checked everything and now at a loss. I have disconnected the rear transmitter wires and got the wife to start van and put into reverse, Used a 12v battery to feed rear transmitter and it works. but again tried to piggyback
the wiring loom it fails to work. Can anybody shed some light here?
