Wiring Diagram For Interior Light
Spaghetti
T6 Conversion
T6 Legend
Hi,
Does anyone know whether there is an ignition switched live in the interior light pod please?
If anyone has the wiring diagram please, that would be great.
Looking to wire a switched twin USB flush outlet on the pod to charge a phone and power a dash cam.
No there isn’t.
There’s a live feed for the courtesy light circuit that’s controlled my the BCM. It turns off after about 20 minutes.
I am not doubting you but doesn't appear to turn off with that install! Well, no mention of it.:cautious: Just going by that post.
Is it possible that it is a switched negative that is controlled which is negated by the dedicated earth that was used for the cam?
Cheers for the suggestions chaps. I’ve bought a 12v to 5v converter that gives out 3A.
If needs be, I’ll run a wire from the fuse box, but it’d be easier if I can tap power off the light somewhere.
Thanks. So... timed to turn off after the ignition is turned off? I presume that timer starts when the door is opened?
Looks like I’ll be pulling a wire up the A pillar!
Perfect, thanks chaps. I’ll have a play with the mutltimeter when the power supply arrives. It annoys me that my phone is on a holder by the mirror and I have a power lead trailing up to it.
Like @Deaky says.
3wires.
BCM Timed switched +ve (20mins-1hr depending on factory installed lights)
BCM switched -ve
perm -ve.
See here. 》
Led Rear Interior Lights - How I Done It.
From that thread:
The courtesy circuit is -ve switched so the wires in the loom are as follows:
Brown - permanent -ve,
red/brown - BCM switched -ve,
red/black - permanent +ve
For me that thread has only confused it more, the two statements are at variance with each other.
I will just have to have a go at mine and see!
I’ll be getting the multimeter out and probing around when I get the time.
From that thread:
I need to tidy up that thread a bit.
This is what you have if you have standard bulbs in the interior.
3wires.
BCM switched -ve
perm -ve.
So , if I want to just switch the light off when the door is open or not I need to put the single pole switch in what coloured wire?
If you just want a light that turns on and off with a switch and doesn‘t come on when the doors are open then you need red/black +ve and brown -ve.
But…. This circuit is on a timer to save flattening the starter battery and will turn off between 20 - 60 minutes after a door being opened or the ignition being turned off.
Reactions: mmi
Or if your just trying to isolate them then put a switch in the red/black wire and that can be turned off to kill them
Thanks guys. I think I’ll try the switch in the red/black first and see if it does what I want.
Theres a coupling point in the dash behind/beside the glovebox (to the left) that the interior lighting circuit passes through, maybe a good spot to isolate and see if it does all lights or just the rear ?
