Wiring into front doors.
paul61
Hi I need to run two wires into each of the front doors, How easy is this to do once the door cards are off and what panels would I need to remove in the van to gain access to the door gaiter, Thanks.
You just need to remove the covers from under the dash each side. Its easier to unclip the bellows too. On the door there is a big foam grommet, pull that out too and your new cables should pass through easily.
