Would these Tiguan wheels fit?
M40CCA
Would these alloys be ok on a caravelle they are from 2018 tiguan r line
255/40/20
No you need a PCD 5 x 120, I presume a caravelle is the same across the t6 range
The other thing you will need to be checking for your replacement rims is their weight rating @M40CCA, which will depend on your axle ratings of the Velle you finally decide upon.
Where will I find these mate, my caravelle is a 2019 exec 150 dsg
I tried looking on the net and could find a vehicle weight of 2389kg but this will be without fuel or passengers wont it?
There will be a black sticker with white writing on it stuck around the bulkhead (prob on drivers side) within the engine compartment.
The last two numbers, one is marked 1. and the other marked 2. indicate the axle weights for front and rear. Take the highest value one and half it. That’ll tell you what your wheel ratings need to be in kg’s.
Thank you
