Hi Guys, Just wondering if anyone had done a conversion/ drilling for the VW roof rails without factory roof prep?
I think its 2 holes missing each side with fitting fitted from under the roof lining?
Be good if someone on here done it already otherwise I won't bother.
TIA Miles
As per title, 2 x roof prep rails, never been used. Only removed to fit the pop-top!
Seen these for £140 per side on ebay a little while ago
£160 + postage
Based in Kent or am heading to Devon via Weston Super Mare on the 28th
Part numbers and pictures below.
LH:
7H1860181A or 7H3860181A...
Have used the search but could quite find what I'm looking for. I have one roof rail attached to my T5 (for the side canopy) but I'd like to fit one to the other side so I can fit a solar panel. Does anyone know if this is a genuine item or where I can purchase the other side? Its a...
I have been wanting to put rails on my Hilo roof for ages. I got pretty much given a set of Thule roof bars and adaptors (Thule parts 7107 and 7009 + wing bars) coming from a California.
All I need I think is rails that would be compatible with that fitting Kit.
I think the one camper van...
Hello,
I have a set of the roof guide rails off my T6 SWB, these are the ones that sit in the gutter and you use t-tracks fittings.
Bought these from new, have the fittings for them but now have a pop top so no longer required.
Part numbers: Left and right channels 7H1860181AQZU AND...
Don't suppose anyone has a set they no longer use? Just had a quotation from the dealer and £250 a side is a bit ridiculous for what it is but I guess that's vw for you.
Cheers
Hi All. does anyone know if there are roof bars available that can be easily fitted and removed? I cant fit rails as it will mean my van is Over-height for the car parks i use.
Is roof rack prep something I could retro fit and if so would it solve the issue. If I do fit roof rack prep do I have...
The things you learn on your first van..
I ordered my van with roof bar prep kit...
(One of the few accessories i requested that they DID fit. :rolleyes: )
So. does this mean if i want roofbars I have to buy the original VW items?? By bars I mean the ones going along the van not crossbars..
Pete
Hello,
I have acquired some roof guide rails, the hidden ones, for a SWB T6
Does anyone have any information about what screws/bolts are needed to fit them?
have tried searching but failed! All I can find are the blanking screws
thanks
My van need to have quite different things on the roof when camping vs working, so I like the idea of the in gutter rails to allow bars to go anywhere.
Can collect within reason, I'm in Chesterfield.
Hey guys,
Just a bit of advice. I have the factory roof rack prep on my van but I’m not sure what bars or rack that actually takes.
I’ve tried doing my research and searching on this site but not much info specifically to the prep.
is there a particular type or can I put some OEM rails or...
