door seal
  1. Grim Reaper
    Best Replacement Door Seal?
    Have had a break in the rubber on the bottom of the driver's door seal for a while now and the resulting rusty patch is getting on my nerves so I want to replace the door seal. There are so many aftermarket options out there so I wonder which ones people have used and whether they think they are...
  2. F
    Door seals from Transporter HQ. Drivers door almost impossible to shut
    I've had a hunt around the forum but can't really find a solution. Fitted them exactly as per THQ guide. I'd read a few posts prior to buying them that the drivers side door would require a bit of extra force to shut it. However, the amount of force I need to use to shut the drivers door is...
  3. E
    Drivers side step insert filling with water
    Hi, I've not been a VW owner for long so apologies if this is a silly question... the step insert on my drivers side door seems to keep filling with water every time it rains. I open the door to get in and all the water seems to rush from the door itself into the step insert. This doesn't happen...
  4. kombisnaps
    Damp ingress by door seal / drivers door
    Okay so - having a new seal fitted soon for drivers door as worn and a bit naff - vw refusing replace on warranty but hey ho. I did fit a v-dubs one but actually would rather keep it all OEM. This post however is for a slightly different issue. When coming to the van in mornings after rain I...
  5. Chopsey
    Door Seal makes drivers door hard to close
    Hi my T6.1 drivers door need slamming really hard to close properly, is there any adjustments I can do to make this easier? Many thanks
  6. DaveCrampton
    Sliding door rubber seat detached. Help pls.
    Hi, my rubber seal at the top of the passenger side sliding door comes loose and I want to fix it. Is there a clip missing here please? We did have an older Focus with door seal issues but the fix was to glue it in place. But from my pictures, it looks like a clip is missing? Thanks, Dave C
  7. G
    Leaking tailgate and sliding door
    We seem to have a leaking tailgate and sliding door in our 23 plate T6.1 Transporter. I wouldn’t have expected this with a 6 week old van but reading though some threads it seems to happen… Water seems to be passing by the seals, not a lot but enough to not want it. I know the best option would...
  8. Heath1984
    Sliding door seal 6.1
    Hi All, Please can someone tell me if the corner of the sliding door seal should look like this?
  9. F
    Replacement front door seal/rubber (not an upgrade!)
    Can anyone recommend a replacement drivers door seal? Recently purchased one off eBay from ‘carclubhouse’, which was recommended and well reviewed for a T6, but the fit is horrendous. The OEM part has an additional flexible section to provide a good seal at the step. Without this, I’m left...
  10. CALLAKN
    Sold Kombi Sliding door seal!
    Got a 4 year old door seal, missing a few plastic clips. But that is easily fixable ! I think there about £200 from VW £50 posted to anyone?
  11. Shaun P Bass
    Door aperture seals
    Hi all. My 1st thread so go easy on me.. Anyway Im looking for advice. Front door aperture seal is split at the top. Is there any upgraded seals?..or should I stick with std ones? Any links would be most appreciated
  12. Alster
    Travelin lite door seals
    Just fitted the travelin lite door seals and really pleased- doors shut with a nice clunk . But just a bit worried that they will fill up with water, should I cut a drain hole in the bottom or am over thinking this. What have others found?
  13. Jason Kew
    Left sliding door seal part number?
    Afternoon T6’ers! I need a new left hand side sliding door seal.. the one on the actual door itself Would anyone know where to get one cheaper than.. just Kampers seem to want £220?!?! Thanks so much in advance:) Ps.. just got back from an amazing nc500 trip.. just epic!
  14. dave_b
    OMG - first DIY job, door seals, what a nightmare......
    only taken me 3 hours to fit the passenger side seal. roof lining will now not quite fit back properly, small gap between it and the seal. B billar, same, will not quit fit back in properly, Lower part, small gaps, a feel as though the plastic has deformed. foot step in not back in place...
  15. Molldog
    Door seals, but what size?
    I know this subject has been discussed at length so please bare with me. Looking to make my van sound like a golf and get some rubber door seals. Had a snoop on E of the Bay and just confused myself. What bloody size do you buy? There seems to be a right old variation of seal sizes available to...
  16. T
    FREE Door seal upgrade
    Bought in error as my van already had it, I was after the dash seal and got both. £10 collection only from KT19
  17. W
    Door seals are meant to come as standard right?
  18. J
    Rubber Door Seal coming away
    HI. I'm new to this forum. I've recently purchased a T6 on a 19 plate, that's only done 21000 miles. The van is in mint/excellent condition however I've noticed that the rubber seal on the drivers door, by the footwell has started to come away. It was like this when I purchased the van a week...
  19. D
    T6 door rubbers
    hi any fitted transporter HQ door rubber seals i fitted one side today seems hard to shut the door you have to slam it hard do thay get easier in time ? thank dave
  20. C
    Is your tailgate seal like this?
    Hi all, My tailgate seal has a gap of about an inch at the bottom. Maybe it's for drainage? It's an easy fix to buy a new seal but keen to know if anyone else has the same? Its going to let a lot of heat out of the van in the winter and after doing all the insulation to a high standard it...
