Can anyone help? I have a 2017 RHD T6 SWB kombi with electric twin sliders. The van is converted to a camper.
When I unlock the van with the key fob and then use the key fob to open the passenger side sliding door the drivers side slider cracks open (just opens).
The drivers side sliding...
Hi everyone,
I’ve have a T6 Camperking conversion and have discovered an intermittent fault with the sliding door.
On some occasions (but mainly on cold / freezing mornings) I blip the key which turns the headlights on and opens all the doors apart from the sliding side door. Both the outside...
I have the following issue with the powered sliding doors on a Caravelle. Both dash door buttons are flashing. The doors power open and close correctly from dash buttons. I can also open the doors from the external handle but neither door will close from the door handle. The doors won't open...
Anyone thinking of retrofitting power closing side door?
I have taken this from my 2010 t5.1 passenger side.
Included is the rail with cable in good condition, drive motor and door module, latch and loom.
I will be removing the van loom when I get chance.
Unfortunately the control module...
Have a T6.1 with electric tailgate.
I have seen that places do coding on the key fob so that you can close the tailgate with the fob.
I have the internal switch to open the tailgate but has anyone managed to fit a switch to close the tailgate from the inside?
TIA.
Whilst my 'Goldie' is being repaired, I have a hire van with electric rear sliding doors. They are a dream to use, gentle pull on the handle and off they go :)
My question to you learned peeps - is this something that can fitted to mine? Has anyone done it and what sort of mortgage will I need...
Hey, I have a 2014 t5.1 with twin electric sliding doors. Both working fine from the int and ext handles and from the key fob but the drivers sides button on the dash has stopped working and I can’t seem to find any info on this. Any help would be much appreciated.
Hi guys I'm after some advise.
I have a 2017 t6 and the NS electric sliding door has a problem.
It will open off the remote key,handle inside and out and the button on the dash.
But won't close, the only way it will close is to hold down the button on the dash.
No lights are flashing and...
It flashes repeatedly on and off with the associated 'Bing'... Despite door being closed, contacts cleaned, wiring checked, battery disconnected (for 10 mins)
I have also tried it by disconnecting the door lead to the 6 pin brassy contact plates. It still shows the driver side passenger door...
Hi everyone,
I purchased a 2012 Caravelle Executive about 4 weeks ago and everything was working as expected up until I tried the disable button for the sliding doors. Since then the button has remained illuminated and the sliding portion of my doors doesn’t work anymore.
I did flatten the...
Fingers crossed here, hoping someone can help me with a workshop procedure for replacing the RH powered door sensor seal?
Keen to know how things come apart
Keen to know if I need to preorder any clips etc before I start?
I taken the van to a dealer to have the tailgate converted to power operation, but it only works some of the time,
I been back to them three time and failed to sort this problem out, they say that it works ok with them, they changed the control panel and
fitted different brackets to where the...
I am hoping someone can help with my electric tailgate intermittently not closing,
This has been going on for 6 months now, the vehicle is still under warranty but VW Derby have now got the vehicle for the third time,
Trip one inspection supposed diagnostics found to be not closing...
Evening,
I would normally happily trawl through threads to find an answer but having just got van back after having fuel filter replaced, I found the sliding door would not shut flush. Trouble is we are meant to be going away tmoz morning as have campsite booked for two nights.
I have had a...
Hi I’ve got a 2020 t6.1 with ten electric sliding side doors
Offside door isn’t working properly- won’t open with handles or on key- but only as you turn ignition on and push button on dash at same time. The button also flashes, then stays lit up constantly
The exterior handle dose not work at...
Hello All, Tried to see if this had been resolved elsewhere.
Sliding door is bouncing back and not shutting. If we try 3-4 times it finally does and sometimes with an extra push.
- Also, when hitting "unlock" on key fob, cannot hear any movement in the sliding door, not sure if it normally...
Hi all.
Just registered and hoping that someone can help with an issue that has started with my van. I've had a look at previous posts, but can't see any that have the exact same set of symptoms - hopefully, I'm not replicating something that's already been covered.
The van is a 2018 - T32 H-LN...
