wheel arches
  1. R
    Slider Door-Store scratches Wheel Arch
    I recently installed an inner side door panel, which has handy slots in which to put stuff. Incidentally, it's not possible to fit this incorrectly (unless you're a complete cretin). However, some month or so after this, I noticed there were deep scuffs on my rear wheel arm and assumed it was...
  2. C
    Wheel arch rubbing.....
    Pulling out of our drive the other day (requires full lock on the steering) I heard a horrible 'gronching' sound. Well, that's yet another noise from my suspension/steering I thought (see here for previous and ongoing issues: Clunk clunk clunk). Upon taking a look underneath I found that the...
  3. DTT6
    Caravelle Sliding Door Card Scuffs Tyres No More
    I finally upgraded from standard 17” Cascavels to staggered 20” Velare VL11’s. The offset and size seemed ok however when the sliding doors open they move inwards about 1cm before they come to a stop. This meant that the tyres and door panel touched at the open resting point. Whilst there is a...
  4. T
    Wanted Rear arch cover
    After a rear arch cover for near side, don't need both as the other is boxed in with my furniture. Fed up of the other one getting covered in dog hair!!
  5. Smileysmile
    What's behind the rear wheel arch?
    T6.1 What is behind the rear wheel arch? If a 8mm hole was drilled from the inside what exposure to air, water etc is there? Can you get to it from under the arch if you removed the arch liner? Cheers
  6. t6blo
    Sold Rear Wheelarch 10” Subwoofer Speaker enclosure boxes & Audison 10” Subwoofers
    High quality carpeted speaker 10” subwoofer enclosures made by Eclipse Custom Vans. They are specially made to fit in the space behind the rear wheel arches and can be used in a SWB or a LWB van even with a rear row of seats installed. Can be secured to side of van with long screws or rivnuts...
  7. Smileysmile
    Interior wheel arch covers
    Does anybody have these? If so, can you paint them and put them on top of Dodo sound deadening? Thanks Wheel arch covers
  8. B
    Inner arch fixings
    Hi all. Does anyone know the exact size fixings for the front inner wheel arch cover on a T6. Broke mine ages ago fitting new headlight and meant to measure and replace quickly. Wait too long, now can’t find to measure. Searched on eBay and google, but no definitive answer. TIA
  9. Adam H
    Best place to run cables
    Is there anywhere at the rear to run cables into the back of the van from the rear, into the drivers rear quarter panel ? Re-converting our van and at some point someone has ran some cables up through the gas vent near the rear wheel arch where the gas cupboard was. We are going induction...
  10. VioletVW
    Wanted NSR wheel arch cover
    Anyone have a NS panel like those found in a shuttle? I have a cover on the OSR as it came to cover the rear heater but would like one opposite.
  11. C4S
    Interior N/S wheel arch panel ?
    Hi, I've just taken delivery of my T32 6.1 Kombi after a LOOOOOONG wait. I ordered it with rear heater, so own the drivers side it has a neat grey wheel arch cover but on the other side there's a wheel arch cover just sat there stuck out, question is? Can I get one for the other side ...
  12. Dogleg T6er
    For Sale A pair of wheel arch boxes
    Wheel arch boxes for sale. Carpet lined as shown (light grey). Made these myself for my day van, but now converted it to a camper. They were very handy for stashing stuff, but now surplus to requirements. Prefer to be collected but I could package up and post if required (at extra cost, and...
  13. archersam
    T6.1 Inner front wheel arches - How To without trimming lip
    I found a previous post that had an issue refitting and so had trimmed the edge that lips over the arch into a gap. This is how I did it without trimming. Mine was done with the bumper off however that shouldn't make a difference. Remove arch - numerous T25 screws and two M8 screw bolts...
  14. abunnyuk
    Shuttle Conversion - Asymmetric wheel arch metalwork
    I'm in the process of converting my shuttle and I've removed all of the rear trim and the HVAC. I've had half-height panels cut by Plyworx and I only noticed when fitting them that VW cut out sections of metal around the wheel arch, presumably for the HVAC, resulting in there being nothing to...
  15. L
    Sold 24L wheel arch water tank - new with accessories
    New in box 24 litre wheel arch water tank for transporters. Black in colour. As per item in link and complete with fitting kit and plumbing kit. https://camperinteriors.co.uk/products/campervan-24-litre-wheel-arch-water-tank?variant=15425379827806 £70 (£118 new) Collection from SW London
  16. C
    Drilling wheelarch for rivnuts?
    Looking at fitting some rivnuts to the wheel arches for securing some furniture. Rivnuts so furniture is more easily removed when needed. There’s a factory metal plate on the drivers side that means I won’t need to drill through the arch itself. But, the passenger side doesn’t have the same...
  17. RunDSG
    FREE Lots of pre-conversion bits —> panels, steps, fixings, windows, etc - remaining parts are free
    I wanted to deliver my van to the converters as an empty metal box, so everything came out! I’m not really sure the value of this stuff. I mostly hope it can be useful to someone, but also a few quid back to towards the van (or a Five Guys) would be great. These came out of my LWB ’67 plate...
  18. McFlude
    Wheelarch tank
    I am just about to order a 24 litre wheelarch tank but thought that I would ask if anyone else has fitted one to see if there are any snags that I haven't considered before I press the button. The bit that rests on the floor is 180 mm and it looks like it could be quite a tight fit between the...
  19. D
    Replacement Wheel Arch Rubber Seal
    Hi There, Please could somebody help point me in the right direction as to where I can source a new rubber seal for the drivers front wheel arch? It's the rubber at the bottom of the wheel arch nearest to the door. Mines starting to pop out from the bottom. Thanks in advance. Dom
  20. J
    T6.1 rear wheel arch cover
    I have just received a new T6.1 with rear heater assembly. I had no idea it would be so large. any guidance where I can buy the same or similar moulding to go the opposite side of the van to make the back look symmetrical? I will be insulating and lining. I think it will look horrible as it...
