Do you honestly believe the stock remap is likely to be the issue? that has probably been installed to loads and loads of vans previous,Was they aware of the remap before the second turbo failure ?
So "stock remap" is not a dynamic remap carried out on a rolling road, or a live remap gathering and adjusting map data, etc whilst driving the vehicle.Stock remap ? Stock means standard just to point out so a remap is not stock. No I’ve not said that, I’m pointing out that the vehicle has been altered from manufacture spec so it is a get out, this is not a blame game at the end of the day, you can’t put ten litres of water in 5 litre bucket and expect it not to spill
I completely agree... and I should have added that walking out with the annotated invoice was the killer. Legal isn’t the route to take at this stage, for sureactually, it's probably "duty of care" under negligence that the garage would have to give you.
But getting legal is not the way to go at this point IMO, just that you do have an expectation that a garage will act in a competent professional manner at all times.
Muck removal and ensuring all was “good to go” is the crux of the issueSo "stock remap" is not a dynamic remap carried out on a rolling road, or a live remap gathering and adjusting map data, etc whilst driving the vehicle.
A "stock remap" has been pre-designed for that engine type; just as the original map has been.
I would guess most remaps are "stock", that's not to say health checks aren't carried out also
But surely any garage has a "duty of care" or "due diligence" to ensure that that there is an oil supply to the turbo etc etc etc before it leaves the garage; particularly if you are replacing a failed turbo that can leave muck and junk all over.
That's a really good point,An on going theme on this site is people take their alleged pride and joys or workhorses to tin pot cheap repairers
Starting to make sense - which is why the remap didn't result in a really noticeable improvement in performance - the turbo wasn't spinning freely, so boost pressure would have been down.if your original turbo was that screwed it would have been seizing over time
I agree - looks like a long slog aheadOP, as you and others have suggested, it sounds like oil feed problem to the turbo. There's no other reasonable explanation (apart from unlikely faulty new part)for the new unit to fail within just a few minutes of operation. It's not difficult to check this when the engine is in bits and the turbo off. Crank the engine over on the starter and see if there's oil flow from the feed pipe, likewise blow compressed air (gently) into the return to make sure not blocked.
To lose a sump full of oil too, within just a few miles, that's very odd, and would be at odds with the oil starvation theory though....
You'd never overstress a turbo to the point of self destruction on a VW2.0Tdi with a regular drive away in just a few minutes. If it was overboosting to the max, I think you'd more likely get a EML light or pop a hose off first. The former depending on how Quantum have coded the map and limits however.
I feel sorry for your plight OP, which ever ways you cut it, I think you're in for a long slog to resolution...
Or oil drain, there is no oil feed without flow and bearing debris is likely to be pushed into the drain not the feed. Both need a thorough check along with the entire induction system.OP, as you and others have suggested, it sounds like oil feed problem to the turbo. There's no other reasonable explanation (apart from unlikely faulty new part)for the new unit to fail within just a few minutes of operation. It's not difficult, as you suggest above, to check this when the engine is in bits and the turbo off, who told you this ?!. Crank the engine over on the starter and see if there's oil flow from the feed pipe, likewise blow compressed air (gently) into the return to make sure not blocked. If the thing runs with no pipe on ever, better, you'll gauge the oil flow too.
ETA - Just seen your comment on Quantum's boost claims. Most of these remaps work due to increasing the fuelling - just like the plug in tuning boxes of old that fiddled the rail pressure. There's not huge gains in loads more boost without introducing drivability issues on motors like this, so they do tend to work on just more fuel. Diesels don't work on a fixed or tight air/fuel ratio like petrol engines, but run on anywhere between something like 15-100:1.
