15 mm dodomat liner, with 50 mm fleece roof t6.1
Ynggunnar
Did anyone with succes fit these two together in the roof? Standard ply, carpeted. I'm finding it hard for it to fit. But I need the thermal insulation for arctic winters x(
I haven't tried with the longer clips yet. But I can't get the holes to apply in each side because the layer is too thick I think.
Any advice?
I have not seen that. is it that you line and insulate with sheep's fleece? Sheep's fleece is sometimes used here as house insulation instead of manufactured products. Afraid I can not help with your technical question but others should.:)
Both products are dodomat.
I can get the clips to fit in the back and one side but then I cannot in the other side, think because of too much material makes it not wanna fit in holes, I'm thinking of drilling new holes, but its such a tight space, I'm not sure there would be enough space for new holes beside the old ones.
If drilling in a tight space you may need an "angled bit". I really hope some one will come to help you because I have never used dodomat. Good luck.
