150PS Engine oil leak on the front
Kocczos
Hi guys, on my 2017 t6 Caravelle 2.0 150 hp engine i found an oil leak, last week the timing belt was changed and the (private) garage told me that is not coming from crankshaft. They cleared the right side of engine and told me to check if still leaking.
Today I found this. Is coming from the upside of the engine, because everything is with oil there, but I can’t find without disassembly.Somebody still meets this problem? Today I will remove the bumper and radiators to make a full clean up and trying to find the problem.
Thank you
Rocker cover gasket, or injector seals on rocker cover gasket would be a likely cause, especially with it looking like its coming from higher up.
Hi @Kocczos, did your get to the bottom of the problem? I think it could be the injector seals but to verify will need to remove a load of parts to get a better look before ordering replacement parts.
Thank you
Had same issue. Tricked me into thinking it was the oil filter housing - swapped that, but still found puddle of oil. Changed can cover gasket, injector seals, retainer bolt seals, and all clean now.
