Hello
I don't think the 17 coopers AT3 are available in 235/60/17 now, and I'm not sure they will be again. These coopers are a great tyre imo for a T6, just the right balance and good in colder weather/ice etc. Just no good for a T32 as the loadings not enough.
Are you 2wd or 4wd? T28?/T30?/T32?
You may which to look also at All-Season options and or Cross-Over the tyres
Have a look at
https://www.mytyres.co.uk/cgi-bin/r...Ang_pro_Seite=10&rsmFahrzeugart=ALL&weiter=10
The General Grabber AT3; and Yokohama Geolander AT GO15 are both good, and the AT3 are been spoken about on this forum(18" size). Just beware of their loading 100 = 800KG = Stamped Maximum axel load 1600kg; usually your rear axel will have the higher rated maximum load. I would very strongly recommend and indeed it may be a legal requirement that your tyres are capable of carrying the maximum load that your vans axels are rated to.
The 235/60/16 size is just the same size as VW OEM trolling radius, so no changes there.
ditto this tyre
Toyo Tyres / SUV 4x4 / Toyo Open Country AT+ - 235/60 R16 100H TL Fuel Eff.: E Wet Grip: E NoiseClass: 2 Noise: 70dB SUV Tyres - 4x4 Tyres - All Terrain Tyres - Off Road Tyres - 16" R16" - 235/60/16, 235/60R16
This is imo a very good price for a Toyo which is a respected tyre manufacturer.
All Tyres » FREE DELIVERY » Oponeo.co.uk
Now the link above is interesting, Personally I like a slightly larger tyre and the 235/65/16 looks so much better on the vehicle, it fills the arches better imo; gives you a little more ground clearance and loading wise these tyres are incredible upto 121 rating = 1450kg/wheel=2900kg/axel; I think your van would snap in half before these tyres let go; not that you need any load rating this high, and the side walls maybe too stiff for a comfortable ride - although I've never tried them. Some of these tyres have All Season rating so good in winter and summer. But these tyres are not really All_Terrain,
Michelin Agilis CrossClimate 235/65 R16 115/113 R C » Oponeo.co.uk - You just now these tyres will be great and probably last 40k miles+, but they are expensive
Nokian WeatherProof C 235/65 R16 121/119 R C » Oponeo.co.uk
I liked Nokin's
Michelin Latitude Cross 235/60/16 are a brilliant tyre load rating is fine, they work really well in all conditions carry Mud&Snow rating, not actually given the All Season the 3PMSF yet, but lots of people use them in winter in Europe. Look beefy, but not quite as Beefy as an AT
You might want to check the speed rating of any tyre as well such S or T etc.
And whilst it's not normally an issue, you may wish to let you insurers now if you fit a non standard tyre
Oh and to get the look you're after, i think you'll need wheel spacers
I've got 25mm on each wheel
Some fit 25mm on each front and 35mm/40mm on each rear wheel
Always go with TUV approved such as HR+ or similar
If you go the AT route, just remember that not all AT's are good in ICE/COLD conditions; because really you need lots of sipes (those small cuts often zig-zaggy) and a compliant rubber compound to work well in winter conditions
Please let us know your thoughts
