18.5l Camping Water Container Replacement Lid
Kev.O
I recently bought a 18.5l container and want to fit another lid with a small pipe that will supply my USB battery tap. I don’t want to use the existing lids as I want the option to use the container independently.
I therefore require a replacement lid but can’t find one online. The diameter of the thread is around 97mm and has 3 threads whereas most yellow versions appear to have two threads.
The smaller of the lids is around 51mm and also has 3 threads.
Any help is appreciated
They look the same as the Kampa 22 (23?) litre one that I have.
I gave up, and bought a rubber bung off ebay which was easy to cut in to.
So it’s not just me that can’t find the exact lid.
Are you able to send me a link to the bung please?
@CAB are you able to send the link to the advert please?
The 37/41 fitted mine perfectly once I had cut out the core and put the pipe down.
2020-05-30-14-39-18-sony-jpg.75308
Have you not tried the original supplier of the water container for a spare?
Just purchased this thank you.
