For some reason they have postage set to £500 at the moment, it was free, something odd going on there!! Probably worth contacting them to see if there's another way to buy etc
Ok so basically the CFCA engine and its bolt on parts are very good except for the EGR valve. All CFCA EGR valves will fail it does not matter if it’s a D variant they can and do fail.
With this in mind if you have had a full engine replacement with absolutely everything replaced costing easily upto £14k it doesn’t make sense to leave a little ticking time bomb waiting to kill your engine again. You can go three routes now.
1) Leave to EGR in place and accept the inevitable.
2) Find a good VW engine specialist to try to retro fit a reliable EGR off of a 140 BHP VW engine.
3) Blank the EGR and fit a Non DPF exhaust pipe and have the engine remapped. Then find a tame and understanding MOT station to help you get your VW through its yearly tests.
Good luck with your quest.
Another problem with EGR on CFCA engines when winter is cold -15 celsius degrees is that engine almost always is cold even with webasto full power work.
This means driving with CFCA without EGR is very uncomfortable.
This is the reason why i'm putting back EGR on my CFCA engine with latest revision of "D" variant.
The D cooler is no better. There's been multiple threads elsewhere of failures on the T6 with that cooler. VW did modify them/the internal coating but it's inevitable.
We don't tend to have winters as harsh as you're experiencing but mine only takes a couple of minutes longer to warm up on the coldest day. Are you sure everything else is in order? Maybe a failed thermostat or similar delaying the engine warm up?
No solid data as I didn't log before emulator/blanking and after but anecdotally I did notice a very small difference in warm up time, but in our temps certainly nothing to worry about. However it drives much smoother from fully cold than before which suggests the EGR is part of the warm up cycle on the CFCA.
Van oil temp is 3-5 degrees cooler on a hard drive than before which has to be a good thing
In my case everything is new. Completely rebuild engine, new thermostats, pumps, everything.
This is the reason why I'm thinking to bring back EGR.
For example, last winter when it was -20 and more, on the highway while you drive 100km/h, engine was 90 degrees, when you drop speed, engine temp dropped quite fast.
