2013 2.0 140 6 speed clutch and DMF part numbers & recommendations
danny-w
Hi all, so Easter Sunday I had the issue of the clutch pedal disappearing on my 2013 t5, no drop in fluid levels no leaks, I’ve bled the system and got the pedal back as a temp fix but there’s obviously an underlying issue. Forum and internet searches describe stories of the slave cylinder being faulty allowing air into the system
So for peace of mind I’m looking to replace the dual mass, clutch & slave cylinder
it’s a 6 speed manual does anyone have any recommendations on what brand to go for? LUK ? Does anyone have the part numbers to hand for the correct parts?
Thanks for any info and input
On a side note, I’ve ordered full genuine service kits (oil, filters, waterpump & belt) to give the van an overhaul while I’m doing the work
I'm converting a T5 to a 6 speed and these are the no.s I found on EKTA.
Flywheel - 03L 105 266 AR or BP - LUK 415 0540 10
Clutch - 03L 141 015 BX - LUK 624 3517 09
Slave cylinder - 0A5 141 671 R - LUK 510 0177 10
I got an LUK 600 032 100 kit from GSF for £354.10 last year.
