@BognorMotors 275/35 is the correct size...? Correct in what terms? I appreciate the 35 profile will be closer to the original circumference hence less speedo/gearing concerns. Anything else?
Hi. Can you send some pics of your van please. Do you have the full ABT kit? I have the ABT ordered ready to go on my new grey t6. Wheels are really important to me and I didn't know what size and design to go forYou said it. Its the perfect replacement, size wise, for the standard size wheels/tyres. There is nothing more to say than that.
@Trev P they are HK Hocks from custom vanz and they come with VW centre caps .Hi Chris, just out of interest what wheels have you got on there and did the VW center caps come with them?
I've just fitted 275/40/20's on my T6 no noticeable change in ride noise or anything APART FROM MY MPG HAS DROPPED OFF THE WORLD!!!!!Tyre dilemma for 20-inch alloys
Currently running OEM suspension on a T30 Kombi
275/40/20 seems to be the go to tyre for 20-inch alloys on the Transporter
If I drop the suspension 40 or 50mm I may (or may not) get some tyre rubbing with the 275/40
If I go for 245/45 I'll probably avoid any possible rubbing. But with the narrower 245 will I still get a similar level of ally wheel protection and ride comfort of the 275/40...?
Suitable load rated tyres are available in both 275/40 and 245/45
Decisions, decisions...any thoughts or personal experience?
Strange that with your speedo as the 35s are the nearest to the rolling radius to the standard size wheels & tyresI had 275/35 on my 20s on my T5.1, and found the ride harsh, especially over potholes. Moving to 275/40s improved things significantly. For my van, the Speedo went from under-reading, to being spot on. There was a bit of heat work needed on the arches though, but otherwise I'd recommend 275/40s on UK roads.
Agree. My current T6 is the same, it under-read Vs the Speedo on the standard 17s, now reading accurately, checked against rolling GPS. Weird but true.Strange that with your speedo as the 35s are the nearest to the rolling radius to the standard size wheels & tyres
