30mm Spacers with Devonports?
Here are the photos - 50mm Springs + Koni's plus 20/25mm H&R spacers....appreciate it's not 30mm as requested but hopefully still useful
View attachment 87640View attachment 87642View attachment 87643
Hello there,
Is this with standard 215 width tyres? Cheers
Hi mate, is that with 215 tyres? Cheers.
Just wanted to thank the contributors to this topic, likely most of you have moved on to newer vans! However it Convinced me to go with the 50mm H&R springs and spacers and stick with the stock alloys
I ran 30mm rear, 20mm front spacers with Davenport (235 55 17) last winter. Lowered around 80mm and was great. Going same setup but with Cascavals this winter (next month)
IMG_6138.jpeg30mm all round on the camper now.
30R and 20F on the work van - big advantage of the 30mm is being able to use OEM wheel bolts so not needing to carry a set for use with the spare, if needed, and much easier to fit the wheels. Through bolts are a pita to line up!
Not sure why folks think less width on the front is better!
