Potentially a little excessive, but certainly impressive! I loved the little chain pull! What a nice chap, bordering on intelligent and considerate! Thanks mate, started my day with a smile!
It may be False Memory syndrome, but I seem to recall someone here on the forum having one of these (or maybe another make of train horn).
Thank you @Howzat , certainly the best (easiest) contender so far!Theres a plug and play option on ebay for £27.50.
VW T5 T5.1 T6 Transporter Dual Twin Horn Plug and Play Upgrade | eBay UK
VW Transporter T5 T5.1 T6 T6.1 Plug and Play Dual / Twin Horn Upgrade. 5 torx screws back in and you are good to go! If so, then this is the upgrade you need - its simply to fit, plugs into the oe horn loom with our pass through loom, and can all be fitted in under 10minutes.www.ebay.co.uk
Give over Wayne - "easiest" isn't the way you roll.Thank you @Howzat , certainly the best (easiest) contender so far!
Your right, Expensive-ist is my usual! That BR or Yankee train horn is my favourite-ist!Give over Wayne - "easiest" isn't the way you roll.![]()
Do it.Your right, Expensive-ist is my usual! That BR or Yankee train horn is my favourite-ist!
Thread 'Horn Upgrade - Summer 2023. Denali Sound Bomb and wiring harness' Horn Upgrade - Summer 2023. Denali Sound Bomb and wiring harness
Is it not a little motorbikey though? Is it becoming of a two and a half ton van?!The 2nd one is plug and play.
Can't comment. The air horn however has them jumping!!! Must admit I don't find the horn on my T6.1 that quiet I feel it needs a change.
