Not sure mate. the brakes keep applying and then suddenly releasing and apparently this issue is linked to the tow bar and it not being disconnected properly. Not sure, I didnt see any codes, just got that screenshot.Trailer module needs un ticking in the module installation list maybe?
can’t see how that would put the van into limp mode though. What are the engine fault codes?
Go into the can gateway which is module 19, then into the 'installation list'
once in there you will see all available modules and the ones that are installed will have a tick next to them
so just add a tick next to the trailer module (number 69) then save and exit
They're a bit too far away to drive it in its current state. Its quite dangerous when it loses power. Im hoping if VCDS can sort it, that I can find someone local on here who doesnt mind popping round in exchange for money penniesDoes your conversion company have VCDS? If so, and you're close-enough that you can drive the van there like it is, I'd like to think its a simple case of unticking the trailer module -
In that case I'll move your posts to a new standalone thread in the hope someone local sees and is able to pop by..They're a bit too far away to drive it in its current state. Its quite dangerous when it loses power. Im hoping if VCDS can sort it, that I can find someone local on here who doesnt mind popping round in exchange for money pennies
Cheers Deaky, very helpful information there.The towbar module (69) will need removing from the installation list within the CAN Gateway Module (19)
There are also entries in the following modules that may need to be removed
Engine Module (01)
ABS Module (03)
Park Assist Module (10)
Never heard of a missing module causing the ABS module to apply the brakes or the Engine to go in to limp mode. Could really do with the error codes from these modules.
How-to in: Post in thread 'T6 OEM LED-headlight retrofit'Thank you. I have OBD11 so I can see the 'Module 69' but if I click on it, i just get this error.
I just need t remve it from its brain so it doesnt think its there. Hopefully the above people can help and very desperate man
Sorry I must be missing something as I cant see it in that thread? (regarding the trailer module removal)How-to in: Post in thread 'T6 OEM LED-headlight retrofit'
Sorry - it was just general idea how to add/remove controllers using ODBeleven:Sorry I must be missing something as I cant see it in that thread? (regarding the trailer module removal)
I'll have a look! thank youSorry - it was just general idea how to add/remove controllers using ODBeleven:
OBDeleven > Control Units > Edit (red pen) > untick the Trailer controller (69) from the list
Engine Module (01)
ABS Module (03)
Update …………
Brandon, owner of @AJCConversions in Glossop very kindly took time out of his evening today and came to my house to sort the issue. A few boxes to tick/untick and off I went for a test drive. So far so good!!
.. He’s certainly one of the good ones who’s not just in it for the money so please consider AJC if you’re looking for a conversion company in the North West. Thanks again Brandon!
