Not seen them yet, usually at the HGV pump. We filled up in Spain last year & they had adblue pumps with the “little boys” pumps, so it may happen.Do they have adblue pumps alongside the regular petrol and diesel pumps?.
Yeah that’s more than at the services on the M62.99.9p a litre...sounds dear to me?. That was at the truck filling pump,dont know if they have it at the "normal" pumps.
Thanks guys...checked the MFD and it shows range at 4000 .Beat me to lol, @Victor19 dont overfill the adblue always put either the minimum or maximum in as it can cause adblue faults.
@Nantgarw?@Taff7996 Ad blue station just off the A470 Caerphilly turn off as you head into Caerphilly, not sure if that's close enough.
Pump shuts off when it's full, that is what happend on mineBe careful not to over fill at the pumps.. it can effect sensors.
Very true but this can also over fill. You should really stop within the range on the MFD.Pump shuts off when it's full, that is what happend on mine
But you can drown the sensor, then the van throws adblue faults.Pump shuts off when it's full, that is what happend on mine
Usually fill mine when the mfd pings think it’s usually 1500 miles, then normally put 9 litres in![]()
I thought that was the opbect of the sensor that it is drowned in the liquid so it can read the level, might as well have dipstick if the sensor is that fragileBut you can drown the sensor, then the van throws adblue faults.
My adblue message is still at 3500miles but I'm getting paranoid reading this thread so I downloaded the findadblue app and thought I'd look for nearby pumps...
From MK, Hayes is the nearest.
From Birkenhead, Oswestry is nearest.
There doesn't seem to be too much concern over keeping these vehicles going!
Luckily most Shell stations seem to sell 5ltr or less in bottles.
So, 1 gallon is 4.54 ltrs, so if your max fill is 1g, will the last ½ltr go off? Presume that's a write off in the scheme of things. Can you throw it, or does it need to be chemically disposed of? Which can be a PITA.
Or can you add it in later if it doesn't go off?
