Hi Guys -
I have a kenwood 9190DABS and it is mounted into a cage style aftermarket mount, there is a lot of movement within the cage, I think the cage itself drops over time putting pressure on the bottom of the headunit which makes it touch screen have a mind of its own, very irritating! anyway to make things worse it appears this pressure has forced the plastic to crack! I am going to try and glue it so fingers crossed but to avoid it getting worse I have seen this:
caraudiodirect.co.uk
I think this holds the headunit instead of the cage? is that right?
If so does anyone know of an installation guide for one of these so I can give it a try? Also does anyone know of one of these mounting units without the microphone hole?
Thanks!
CT24VW12 Facia Plate for VW Golf 2005> 2014
This fascia kit allows the installation of an aftermarket head unit into a non din sized aperture High quality finish designed to match the vehicle dashboard Complete facia kit, supplied with either brackets or metal cage to mount the afterma
Thanks!
