That's correct. T6.1 BCM has no codings. Everything is done via Adaptations - for that BCM more than 1500 channels to tweak.BCM does not support coding
Thanks for your input…that would explain why I can’t access it then via coding, I’ll give it a try again in the morning. Fingers crossed that will sort the issueAdaptations in T6.1 with fog lights:
And, T6.1 without fog lights - perhaps you could try these.
Possibly this gremlin - especially post #2.have you done a full auto-scan before you started i found this can sometimes help for some reason
Thanks for the info…makes an interesting read. I’ll give it a go in the morning and see how far I get with it.Possibly this gremlin - especially post #2.
Also here (post #7)What can I do here?
forums.ross-tech.com
HEX NET problem with WIN
In last time very often i have problem with detecting VIN and after that problem with correct ROD file.This evening it frustrates me because can't change brake pads at Q7 2017.What can be done?eforums.ross-tech.com
I have updated the HEX-V2 firmware to 4608 (by switching into Beta channel in the updater) - so far so good...
Thanks for all your help…I have finally got back round to having a look at this. I have backed up the adaptions as a hex file.It's probably a good idea to backup all the adaptations before any changes!
Raw Hex -output format is the tool for that.
More here:
I made the changes that MMI suggested in a previous message, worked a treat once I found the security code to allow the changes.For future reference what adaptatioslns did you change
Do you know what channel it is to switch off the PWM on the reverse light as I am getting a flicker on my reverse camera?Adaptations in T6.1 with fog lights:
No, not really. However, the channels related to reversing light have designator "Leuchte28RFL C3", thus possibly tweaking channel "ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28" could be related?Do you know what channel it is to switch off the PWM on the reverse light as I am getting a flicker on my reverse camera?
Yes halogen bulbs, how would you verify the supply is PWM?No, not really. However, the channels related to reversing light have designator "Leuchte28RFL C3", thus possibly tweaking channel "ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28" could be related?
Have you verified the power feed is actually PWM?
Are your reversing lights LEDs or halogen bulbs?
A proposal to filter out possible PWM:
Garmin Bc30 Reversing Camera Q
Hi folks Thinking of fitting one of these as I already have a suitable sat nag. Linky According to the fitting instructions, it suggests using a switched live taken from the reversing light. My Q is will this work on my T6 or will the cambus go all wobbly on me. Cheerswww.t6forum.com
