AGM VSR B2B , T5 2011
emjga
Folks
When I bought my T5 2011 , converted in 2013 , about 3 months ago.
I knew the leisure battery was done in and not really holding its charge.
It was a 80Amp Wet lead acid battery.
Since I will be mainly doing off Grid , Moving on each day / night
I bought 2 X 100Amp AGM (Anything bigler would not fit in the space)
The Van has a VSR (I assume) as there is nothing the leisure battery area.
I know VSR dont work very well with AGM
Shortly I am going to install solar and a suitable solar controller that supports AGM.
Should I be changing out the VSR for a B2B charger as well (A lot more expense and I suspect will have to run a new cable from the starter battery )
Or just leave the VSR in place and use the solar to top up the AGM
If it makes any difference I live in Scotland , Aberdeen
Most of the trips will be in Scotland so shorter sun hrs in the winter.
Any thoughts
Matt
Definitely look at fitting a dc-dc charger.
Even though you've got T5 and a VSR etc you will be better off with a proper battery charger.
Solar will help obviously while the sun's out get a bigger panel as you can afford for the roof if and look at getting a decent mppt solar controller.
Next time you think about upgrading the batteries look at lithium.
Posting pictures of your setup and van so we can see what's what.
More info.
Thanks , that is the answer I was expecting.
Think that is going to be my next little project.
Need at least a 200 watt.
Not sure about just one big panel (More expensive) or 2 X 100 watt
Then have to decide parallel or serial
Live in Scotland and will be mainly in Scotland for trips.
Just replaced from single 80Amp wet lead battery to 2 X 100Amp AGM
Did look at lithium but just could not justify the cost.
