What is actually happening when you switch on the air con? I have standard stuff, not climate control or anything.
When I get in the van at the end of a hot day and it stifling in the cab, I turn the temp right down, switch on the blower to about 3, and press the air con button. I've never had a vehicle with aircon before. but after about 4 minutes of driving, a second louder fan comes on somewhere under the glove box. Why is that then?
Also, when I put it into reverse, some fan under the dash again goes into turbo mode! Its all a bit bizarre. Can anyone explain to me what is going on?
One final question is how do I know if my air con is working in tip top form? As in, getting as cold as it should.
Thanks!
Adam
Thanks!
Adam
