@MotortechSorry you feel i am rude but that is certainly not as intended i will however refrain from posting in futureapologies if anyone has been offended!
@Motortech
Your knowledge and advice was very much appreciated and I for one hope you remain on the forum and continue offering your advice.
I don't think anyone was offended, we are all pretty thick skinned on here.![]()
I recall from some years ago, emergency services been given the heads up about AC refrigerant.
....."In case of fire it releases highly corrosive and toxic hydrogen fluoride and the highly toxic gas carbonyl fluoride"....
Unfortunately, back then, it was part of my job description to poke about with crashed and/or burnt out motors. So this warning really filled me with enthusiasm for the role.
Current T6's use R134a refrigerant, which is the most common gas in use and has been for the last 20 years or so. R134a is being phased out now and most new vehicles are being type-approved with R1234yf which is hydrocarbon based and is mildly flammable (but really nothing to worry about).
All vehicle aircon systems loose gas via the compressor shaft seal and the rubber hoses, the current maximum allowed rate is around 60g per year. I find that an average system that has never been serviced or recharged will stop cooling after 8 years or so as the gas pressure will be too low to operate the pressure switch, which is there to protect the system from running with insufficient refrigerant (and therefore oil) circulating.
I have found on the T6 that the aircon will shut down if the battery voltage drops too low (not certain what voltage exactly).
I work with new unregistered T6 chassis so they are MY 2018/2019 and all are using R134a. As they are type-approved R134a, they will be able to carry on being built with it until 2020, as I understand it, after that it will have to be R1234yf.
