Airbag light resistor cheat
Without me sounding daft is this mod just a case of pushing these into the yellow connector?
how do they stay in? And do you cover them with insulation tape was fitted
thanks
Paul
I found just pushing the prongs in wasn't secure enough, the prongs wanted to pop out of the connector sideways. I folded the pins back on themselves then inserted them, which made them stay put. Just folded the remainder against the yellow plug and taped them
thanks
Paul
Yes I pushed them in but put them into a clear plastic pouch and zip tied the whole lot together, then tucked it under the cab carpet.
My light came on again. I found the original resistors and replaced it. It didn't clear the fault. My garage found the measured value on his computer was 1.9 ohms despite the 2.7 ohm resistor. I replaced the replacement with the original and it allowed the fault to be cleared.
But today the dog stood in the gap between the seats and the airbag light came on...
I think I need to solder the resistor in...
Newbie question. I have front bench seat on my t6.1 with occupancy sensors, no airbags. I want to fit a swivel base and need to frig the occupancy sensors so I can fit under the floor. Is this thread relevant to my issue?
Hi
Does anyone know what type of connector the yellow one is?
I did find a thread where Pauly had made an extention cable but I can't find it again. Thus allowing the air bag to be disconnected and reconnected from out side the swivel base area.
I just cut the wires to the yellow connector and made an extension with two sets of connectors. The issues arise when I needed to drop the windows to hook up the solar connector to the leisure battery with the seat swiveled and disconnected. In the end I just bought a single seat and used the resistor to blank off the sensor for the now removed seat belt.
I wondering if there is a ware switch to turn that sensor off in the ECU so I don't have to use the resistor.
Dave, I was think more the air bag in the dash. I don’t think my double seat has an airbag. I understand it has occupancy sensors so it knows someone is sat in the seat and where they are sat I.e. next to window or driver, that’s how I understand it?
Hello, i m writing from italy, i have the same question of you... i have replaced double seat with airbag with single seat without airbag and put a resistor to cheat side airbag error. Now the airbag have no error but he single seat have no weight sensor so it is like nobody is seating there ... the front airbag will still work in case of an accident ?
thank you
Filippo
Morning forum,
Please help, MOT due in a couple of weeks!
I have an airbag light warning after replacing the bench seat with a single. I have a bag full of resistors, but I don't have a yellow plug under the seat, or any plug with the three coloured wires.
Confused?
Van is a 22 plate T6.1
Mark
@earthmover
Not familiar with t6.1 as mine a t6
Did you swap seat yourself ? Is it possible that your double wasn’t airbag seat if no yellow plug, or has it not been pushed under the flap in carpet/rubber flooring.
Im probably stated obvious which you’ve already checked, really need another t6.1 owner really to advise if indeed it’s a yellow connection on newer vans, hope you get sorted on this one, what happens if you get airbag light reset on diagnostic machine does it just come back on, which would indicate defo the seat connections
Hopefully someone more knowledgeable than me will be along to help you
