Well I’ve recently got rid of the tyre hum (Cargo Vector M&S) so looking forward to loosing a bit more engine noise after doing the scuttle.
I wouldn’t change my Cargo Vectors, they maybe a bit noisy but they stick to the road like glue and I’ve just got 41K miles out of one pair, the other pair still have approx‘ 10-15K to go.
41 Thousand miles!!! That's fantastic, I'd stick with that tyre then.I haven’t tried the Nokian and Continental but the Cargo Vectors are great tyres. I can sometimes go offroad so I like the ‘van‘ tyre.
See below regarding milage, stock T32 suspension, 180PS driven fairly gently.
41K on the front pair, switched rears to the front, from the tread depth I should get 51 - 56K from that pair.41 Thousand miles!!! That's fantastic, I'd stick with that tyre then.
Hi - forgive my ignorance - new on here. I’ve just bought some Devonports with delivery miles - Contivan 215/60/17 104H for my T32. When it comes to replacement 235/55/17 are a safe option are they? Thought I’d have to be sticking with 215/60/17. Cheers, MikeTime is approaching to replace my tyres on the factory 17" Devonports - currently fitted with Goodyear Cargo Vector 2's
My proposed replacements:
I'm looking for longevity and quietness, plus the benefits that an all season tyre provides. The Nokian and Conti are SUV tyres in 235/55/17 the Goodyear is Van rated and 215/60/17 all are load rated for a T32.
- Nokian Weatherproof (£100)
- Continental All Season (£120)
- Goodyear Cargo Vector 2 (£140)
Advice and opinions welcomed.
TIA Paul
Devonports can come from the factory with either size. Mine came with 215/60 and I changed a year ago to 235/55. Just make sure the load rating of whatever you get is high enough for a T32Hi - forgive my ignorance - new on here. I’ve just bought some Devonports with delivery miles - Contivan 215/60/17 104H for my T32. When it comes to replacement 235/55/17 are a safe option are they? Thought I’d have to be sticking with 215/60/17. Cheers, Mike
Thanks for the reply - good to know. And yes, nothing less than 104H right?Devonports can come from the factory with either size. Mine came with 215/60 and I changed a year ago to 235/55. Just make sure the load rating of whatever you get is high enough for a T32
In my case, the only difference in feel was being able to run the tyres at lower pressure which gave a bit more comfort. No difference in handling that I could tell. Slightly better looks with more width.Can I ask generally - 215 v 235 options for Devonports - pros / cons to both? Cheers, Mike
Interesting. I’m running these 215s as per the sticker on the vehicle - 52 front, 46 rear as not carrying weight. Do you reckon even with these tyres I could drop pressure a bit? Ps - any effect on your speedo going to 235?In my case, the only difference in feel was being able to run the tyres at lower pressure which gave a bit more comfort. No difference in handling that I could tell. Slightly better looks with more width.
My speedo was slightly more accurate after fitting the 235s. I run 42 front and rear which I’ve found feels best after much experimentation.Interesting. I’m running these 215s as per the sticker on the vehicle - 52 front, 46 rear as not carrying weight. Do you reckon even with these tyres I could drop pressure a bit? Ps - any effect on your speedo going to 235?
