Quick question for those who've dealt with this issue, as I haven't been able to find an answer via search.
I'm almost certain I have this fault based on the van's symptoms.
So I had a look at the loom by the sump today. However the green/yellow cable looked healthy. I decided to replace it anyway since I'd already stripped it. I took out as much as I could easily get to (about 25cm). However the continuity of the bit I've removed was fine so I'm not expecting replacing it to make a difference.
Is there anywhere else easy to access that this cable commonly fails? I don't fancy trying to remove the whole length.
