Brilliant videos thanks
If I don’t need to make any software alterations then that makes me a lot happier 1st job when I get my van back will be to measure the current usage before I do anything, so thanks for that tip.
Max running time is 3 to 4 hours twice a week, with about an hour the rest of the time. I had to change how my current amps feed the speakers as one amp was over heating and shutting off after 2 hours, that said since I have fitted an Flettner vent it has made a huge difference as to how warm they get and splitting the amps to left and right side cured the problem rather than 2 woofers on one amp before it was fitted.
I need to measure my current usage, but im starting to lean towards fitting two 8 inch subs over one 10 or 12 inch because a sub under the drivers and far side of the passenger seat should sound better, I’ll lose depth but I’ll gain better sub integration with the mains. But it has the added benefit of lower power consumption which might allow me to get away without adding a 2nd battery (might is the key word )
1st job is to measure and see then, but thanks to you @Dellmassive I have options now if one is needed
