Hi @deadmanshand
I had the same problem as you.
I ordered a set from THQ
When I went to fit one, it was too loose as you reported
After numerous calls and emails to Kieran and Mikey at THQ, it turns out they had a mix up with their stock and Transporter and Crafter caps had been mixed.
I received 2 Transporter and 2 Crafter caps.
I only tried to fit the Crafter one. I thought I was going mad.
The code you need is 7E0 601 151B . This is for the Transporter.
The Crafter code is 2N0 601 151 B
They look identical.
The only difference is that the Transporter one is 25mm dia, where as the Crafter one is 28mm dia.
Hope this helps
Hope this helps
