Hi
Recently fitted H and R ARB’s
I must say the handling is much improved, hardly any roll in the corners and the van seems more planted and firmer ride which I like ( have 40 mm h r springs)
The problem I have it is a bit crashy / harsh and noisy now over small bumps on the road , not so noticeable at higher speeds .
I did check under the van that all the bolts were fully tight!
I have been told to check/ lower rear tyre pressures to soften the ride , tyres are 275/40/20, so not the lowest profile tyres anyway
What do you guys think?
