Are battens needed for flooring?
Smileysmile
I've been researching a lot.
9mm thick battens fitted in between floor ribs. Are they necessary for a 9mm or 12mm thick plywood? Would they be used if only you screwed the floor to battens?
Aren't the factory ribs spaced for flooring anyway without the need for battens?
I read a post I'm sure adhesive was placed on the ribs then floor was placed on top.
Thoughts please.
