Sold Audison Prima AP5.9Bit Amplifier with ASP and Loom for front speakers.
Skyliner33
VCDS User
T6 Legend
I have the following items for sale:
Audison Prima AP5.9Bit RRP £649.99 SALE PRICE £619.99
Audison Prima ASP signal Presence: £47.99 This is to stop the head unit from turning off.
Audison AP T-H AVS02 VAG 52 pin SALE: £56.99
AUDISON PRIMA AP 260P&P IN 260CM ISO PLUG & PLAY EXTENSION LEAD AMP INPUT Sale Price £52.24
I will also include the speaker out loom that I made, to run the 4 front speakers on 4 channels. This will need some work as the speaker plugs ned to be attached after the speaker wire is fed through the door. Unless you use the OEM wiring. Then its just a case of wiring the output loom to the OEM plugs. I can provide detailed instructions if needed.
The amplifier has been connected to a laptop and the Audison software been used to set up the amp for use in a T6.
Total cost for these items is around £750.
I am looking for £500 ono plus PnP
ECA8225E-E09C-4893-85FA-98B4ADCD9108_1_105_c.jpeg75348787-A74A-44CE-A71F-840F7DF4C959_1_105_c.jpeg5DFE6B3A-C77B-48B8-AB67-EA39B9749C45_1_105_c.jpeg3FD31AC3-442B-4320-B9E3-6D426A14C9D1_1_105_c.jpeg
