Has the start stop not worked since new battery fitted ? is it a daily user or camper parked up mostly ?
Is the new battery the correct type for the van (AGM ) for the start stop charge and discharge feature ?
Has the re-placement BTB charger caused the issue ..?
work on the battery drain issue first and the tackle the other issues …
Is there something possibly draining the battery ? Dashcam or something left on ?
Have you had any mods or add -ones that may cause the battery drain ..?
‘The stop start on my van doesn’t seem to operate until everything hot and generally on longer runs as it’s a camper and sits on the drive a lot with low battery volts .. possibly needs to charge battery to level for SS to activate I’m guessing ..Other more knowlegable on here may be able to help if the post is seen enough…
search for stop start and battery issues on the forum .. others may have had similar problems
