Agree lets petition VW?Yes, I appreciate that they will only offer options if they think there will be s significant up take. But auto folding mirrors, would nearly need to be designed out of a modern vehicles can-bus architecture?????
Hi peeps,
That's my post on the Ross tech forum, I have my mirrors on my 2015 T5.2 working via key fob with coding only, if anyone's up near warrington way I'm happy to give it as shot
I have the vcds, could you tell us what we need to try for the T6?Hi peeps,
Can you let us know what vehicle/age etc it worked onI thought the sameBut viola it works
I've had a go does not seem to do anything for meCertainly, in cent-elec 09 ,select door modules and you need to select byte2 bit1, you most likely won't have the box there to check so you will have to work out what the HEX value will be and then input it manually, then you need to read apt your window limit stops (very important or it won't work)
As stated in my Ross tech post, mine are 'L' revision four modules,, these are the only ones I know will work, so if anyone is near warrington I'll give it ago for you
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 238162048
Coding: B8A430B80A633431922846D07E2B9451FF8463FF608C00C0320000030840
Shop #: WSC 35110 377 00155
VCID: 2A5136E4455186119D-807E
Subsystem 1 - Part No SW: 7E0 959 801 L HW: 7E0 959 801 L Labels: 7E0-959-801.CLB
Component: J386__TSG_FT 003 8653
Serial number: KU0KU020011550208704
Coding: 1500B3
Subsystem 2 - Part No SW: 7E0 959 802 L HW: 7E0 959 802 L Labels: 7E0-959-802.CLB
Component: J387__TSG_BT 003 8653
Serial number: KU0KU021011550215028
Coding: 0400A3
Subsystem 3 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 5 - Part No: 7E1 951 172
Coding: 000000
Subsystem 6 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A
Component: E221__MFL-DC1 H02 0103
Serial number: 29150002474260086043
Coding: B4FFFF
WOW WOW WOW @Adams you are a legend !!! This is working for me this morning i cannot believe it .here is my BCM coding
Code:Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 B HW: 7E0 937 090 Component: BCM PQ25 Max4 H81 0744 Revision: B9081001 Serial number: 0982 238162048 Coding: B8A430B80A633431922846D07E2B9451FF8463FF608C00C0320000030840 Shop #: WSC 35110 377 00155 VCID: 2A5136E4455186119D-807E Subsystem 1 - Part No SW: 7E0 959 801 L HW: 7E0 959 801 L Labels: 7E0-959-801.CLB Component: J386__TSG_FT 003 8653 Serial number: KU0KU020011550208704 Coding: 1500B3 Subsystem 2 - Part No SW: 7E0 959 802 L HW: 7E0 959 802 L Labels: 7E0-959-802.CLB Component: J387__TSG_BT 003 8653 Serial number: KU0KU021011550215028 Coding: 0400A3 Subsystem 3 - Part No: 7E1 951 172 Component: DWA-Sensor 00 001 0104 Coding: 000000 Subsystem 4 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Coding: 000000 Subsystem 5 - Part No: 7E1 951 172 Component: DWA-Sensor 00 001 0104 Coding: 000000 Subsystem 6 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Component: E221__MFL-DC1 H02 0103 Serial number: 29150002474260086043 Coding: B4FFFF
