@Nickdaw ,has just tried mine ,not working with Q module .
Back to the drawing board
just a thought is yours set to close the windows when hold lock?comfort feature must also be activated (opening/closing windows via fob)
Just tried ,if I hold button to unlock ,windows come down and go up when holding to lockjust a thought is yours set to close the windows when hold lock?
Mybe it has something to do with the euro6 having live feed to the mirrors once the door is opened, unlike the euro5 ???
so the comfort setting is on like mine,Just tried ,if I hold button to unlock ,windows come down and go up when holding to lock
Is this any use ? If not @Nickdaw might be able to send you the restJust had a quick look at the T5.2 / T6 (2016-2017) and nothing changes, all mirror folding related pins are the same and door modules still have permanent feed, I'm guessing it's just down to the modules on the later ones
Also if anyone that has Euro6 can send me a VCDS autoscan and adaption channel map of cent elec I'll take a look through it.
Adaption channel map - Applications > controller channel map > type in 09 for controller address > check box for adaptions & CSV file.
After it reads all 255 channels it will save in the VCDS logs file
ill have to redo the scan for that CarlIs this any use ? If not @Nickdaw might be able to send you the rest
View attachment 5014 View attachment 5015
I sent a channel map to Ross Tech a couple of weeks ago, I'll dig it out tomorrow .Just had a quick look at the T5.2 / T6 (2016-2017) and nothing changes, all mirror folding related pins are the same and door modules still have permanent feed, I'm guessing it's just down to the modules on the later ones
Will this stop it working if it is set to activejust a thought is yours set to close the windows when hold lock?
I think its the opposite, it wont work without itWill this stop it working if it is set to active
