Odb fuse is sc14Thanks Loz - can't see on you dial which fuse supplies obd port - my scanner lights up and display works when plugged in
when you turn the key to crank power goes through fuse sc56 to the ecu to command start, at the same time power flows through fuse sc23 and onto the first relay j907 and then onto the second relay j906 both these relays are commanded by the ecu, and that depends on the status of other things, not immobilise, in neutral etc. both these relays are in the ebox under the starter battery.
its quite feasible that extra relays were added as part of the conversion to inhibit start or even start without having to turn the key? etc.
