Bentley Wheels??
Hi All,
As I have a T32 T6 I'm struggling to find any aftermarket alloys that I like and I like the look of the Bentley wheels on the Transporter. Does anyone know what the load rating of the Bentley wheels are or where I can find this out?
Also I'm aware the newer Bentley wheels are 5x112 PCD so I'd need to purchase adaptors to create the 5x120 PCD for the T6, has anyone used these before and how safe are they?
Many Thanks
Previously members have detailed the Bentley wheels but my understanding is there is no suitable load rated tyre for a T32 as it needs a minimum of 103 to suit and axle/wheel rating of 860kg.
It's worth looking through other wheel threads
I have seen a set of 21" Bentley rims with 103 tyres on a transporter. Customvanz sell them.
will 21 inch Bentley GTC alloys fit my t30 275/35/21
Thinking of getting B14s as well
Cheers Steve
I have seen these fitted on a T6.
You may need to mould your inner arch liners a touch though.
I will leave it if I have to do that!
Thanks for info
It’s normally only a case of applying a heat gun to them and shaping them with your hand.
A 35 profile side wall though on a 21” tyre is likely to be rather unforgiving and you’d feel every lump in the tarmac.
As you can see I am already running on SSR 1's but I would like to get a spare as these are bigger than the factory steel under the body (spare ) and this is a 4motion model .
I almost ordered a new rim today until I mentioned it was going in my T6 as a spare and suddenly and apparently it would not fit due to the centre hub size , so I mentioned that I was already running around on four SSR 1's but was informed that these wheels were a special order by a dealer ?? WTF !
Does any body on this forum have some reliable info on this fitment and where I can pick one up , my last Quote was £286 all in .
