Also think about the tent fabric you want. Mine is proofed canvas, which is very breathable and I don’t get condensation. Stays dry inside. Others have a vinyl which is arguably more waterproof but less breathable, and more condensation prone.
That's a fair point, but might be more useful for the OP if you share which pop-top you have.
Not sure which roofs have a vinyl canvas, but the Hilo has a high quality, marine-grade canvas. Not sure if that's the same as water-proofed. but never had any water ingress.
I did- PopTop Roofs, AKA Streamline
My bad for not reading thread the entire thread. :whistle:
I see Hilo/Horizon now has 60Kg roof loading, which would put it back on my list. I was picking mine in Autumn 2022, so not the right time to be going Hilo.
That was just a bit later than when I bought mine... though it wasn't fitted until Feb/March 2023 due to van delivery delays.
For options, do go for a bifold bed. Gives you much more headroom than a flatbed.
Or go for a pop top that uses removable panels rather than a pull-down bed. On a trip when you don’t need them leave them at home. We have only taken our bed panels once and on all other occasions have benefited from extra headroom when the roof is lowered.
Sorry late to the party but I would make sure you have a slide board to cover the underside of the poptop once lowered above the drivers seat cab area
Or have a pop top that doesn’t extend the cutout over the cab area. Gives some extra storage space when the roof is up and likely also makes the vehicle cab stronger in the unfortunate event of an accident.
Lots of options!
Have a look at HVR customs at Lee on Solent. They did a Vanmax for us which is an excellent roof but only in swb. They also do Skyline and Lowlife
Hi - hope you are all enjoying the lovely weather and out there in your campers .
We are still searching for ours - almost there I think but just wanted some advice on Pop tops. Are there any that stand out about others , anything we should look out for. We are looking to buy one already converted but need to know if there any pop tops we should be looking out for . Thanks in advance x
Difficult one - everyone will have their favourite pop-top and it's usually (but not always! :oops:) the one they chose.
One thing to consider is whether you want/need to be able to leave bedding in the pop-top when it's closed - such roofs are sometimes, unkindly referred to as upturned bath-tubs - or whether you want/need the roof to be unobtrusive and inconspicuous (at least to the uninitiated) - a so-called "stealth" roof. Each has pros & cons, but I've yet to find a roof that satisfies both requirements.
Another thing to consider is who will be sleeping in the pop-top. Young children will probably be fine with a rigid bedboard and SIM, whereas older teens and adults would probably want/need the additional comfort afforded by a slatted bedboard or a bedboard incorporating a Froli spring system.
Also consider whether you want/need a bi-fold bedboard. Roofs with these afford a lot more headroom at the back of the van (when raised) than those with a standard single-hinged bedboard.
Finally, the price. Pop-tops can cost anywhere between £2k to nearer £9k, so your budget will influence your choice of roof.
HTH
Anyone done a Shuttle with pop top that can offer some advice?
Thinking about one but don't want to loose the climate control from the rear section.
Would also like it as stealth as possible.
For a stealth Shuttle install I would reach out to Slidepods - they have a guy who specialises in pop tops in the shuttle and Caravelle. They retain the AC and as factory as possible. Had a quote form them but decided to buy a new van instead.
that expensive huh! :laugh:
I’m looking for a pop top for our recent van purchase.
Our priority is height at the front and rear (bi-fold must be an option) as I’m 6’4.
Horizon would bed perfect but way out of our price range.
Skyline (standard SWB) is another option but I’ve read about the Auroras opening on motorways, any idea if this fault also exists with the standard versions?
Any other ‘decently priced’ pop tops that provide maximum headroom at the front and back? Cheers!
