Dariusz131
Hi, what bike rack And Roofing reils will you recommend? I’m thinking about coating them also black. Thank you
Hi @Phil Harris and @Gingercoastie ,
Powder coating was by Technique Finishing Ltd – Just another WordPress site in Chichester. Cost £120.00.
The only issue I can see after using it for a few weekends away is were the bottom bar rotates against the upright. slight paint scuffing.
All went back together OK spent some time locating the correct Black rivets.
That looks awesome! Where did you do yours if may I ask and how much did they quote?View attachment 22867 Finished.![]()
Hi,Thanks for the tip, I contacted Dale from Technique Finishing and his quote of £250 seems slightly overpriced. I'm looking for an alternative if anyone could recommend another company?
Also... I have a question - did you manage to disassemble all plastic parts? I have two elements where I was unable to separate the plastic - how did you paint those?
Hi,Ah great! Thanks for the update.
I wasn't sure what to do with the rivets as they're factory done.
So you're anodising in black right? May I ask why you choose anodising rather than powder coating?
Where are the tubes coming from?
And one more (most important) questionwhere are you doing your bike rack?
Please send pictures once it's done - really keen to see the final effect.
Many thanks and regards,
Lakis
will do..... as soon as I knowCan you post a link to the correct rivets for reassembly please (and how you fit them).
Have you had a quote for the anodising? I don’t imagine it will be very cheap as the prep’ will be considerable. As far as I’m aware the inside of the tubing will also need to be decontaminated to avoid a poor finish.Hi all, I recently bought a genuine bike rack for my T5. I want to dismantle it to get the aluminium bits anodised black. However I’m having 2 problems:
1. Getting the rivnuts out
Every rivnut is spinning in the aluminium tubes. In fact there were a few that the thread lock is sticking the bolts into the rivnuts so tightly that I had to drill the heads off the bolts just to get it apart. Has anyone got any tips for drilling out a spinning rivnut?
2. Removing the rivits on the main plastic feet
I’m not sure how to get the rivits in the picture out. Is it just a case of drilling them out and finding a replacement? What have people used to put it back together?
Any advice appreciated. Thanks!
I’m just outside Belfast. There are a couple of local places, but they want pictures and dimensions before they quote. If it’s too expensive I’ll fall back on powdercoating, but I just fancy trying to get it anodised.probs have to drill them out!!! can i ask please where are you getting it anodised? Im looking into doing the same . and have read anodising is better than powder coating cheers Jon
Can you use the rivnut tool to retighten the existing nuts before drilling them out ?Has anyone got any tips for drilling out a spinning rivnut?
Everything to do with a T5 is ball ache!
