Loz Senior Member Admin Moderator VIP Member 19 Jun 2019 #21 Latest addition to brand Cheaparse® is the top up tube. This allows a quick respray with the Autoglym black dye in situe.
C Cryne2 New Member 20 Jun 2019 #22 Loz said: View attachment 23417 Click to expand... Are the centre caps 65mm. Just putting some steels on mine...thanks
Loz Senior Member Admin Moderator VIP Member 20 Jun 2019 #23 Cryne2 said: Are the centre caps 65mm. Just putting some steels on mine...thanks Click to expand... No, 55mm and glued(hot glue gun) into the actual hub with a small hole drilled in them for expansion otherwise the fronts can blow off.
C Cryne2 New Member 20 Jun 2019 #24 Loz said: No, 55mm and glued(hot glue gun) into the actual hub with a small hole drilled in them for expansion otherwise the fronts can blow off. Click to expand... Thanks. Off Ebay???
Loz Senior Member Admin Moderator VIP Member 20 Jun 2019 #25 Cryne2 said: Thanks. Off Ebay??? Click to expand... yup
