Hi guys and girls , looking for some help , I have retro fitted a factory sunroof but struggling to get power to it , I have fitted the oem loom from the donor van , will I need to get the bcm re programmed to allow power to it ? Many thanks Steve
Cheers Rob
Thanks again mate , last question !!! I hope , if I have the fuse missing then what size would you fit ? Cheers Steve
Still not working guys , will it need to be told to send power to fuse 48 on the bcm ?
Hi Rob, do you possibly have a diagram for the electrics on the van ? So I can work out where the wires go to from the block connectors that are behind the glove box ? Many thanks for you time mate
Have you looked here?Hi Rob, do you possibly have a diagram for the electrics on the van ? So I can work out where the wires go to from the block connectors that are behind the glove box ? Many thanks for you time mate
Hi paddy , yes I think so but this is where in struggling as don’t know how theses actually go to in the bcm ??Which pins in the green connector are missing wires?
The wiring diagram linked above shows 2 wires going from the green connector to the bcm. Is it these ones you are missing?
Hi Loz , yes. It struggling to find which one I need to show me the green connector going back into the vanHave you looked here?
Downloads
www.t6forum.com
The black connector on the bcm. There is a guide on here how to access the bcm. Pins 35 and 48.Hi paddy , yes I think so but this is where in struggling as don’t know how theses actually go to in the bcm ??
Yellow/red to 35.Thanks paddy , which wire to which position mate ?
