BODY LIFT OPTIONS
Mosher
HI.
1.Please advise for body lift options 30-50 Mm for T6 california ocean
2.Which is the largest tyre size [diameter] that the T6 can accept without suspension change?on 17 wheels
tanks
245/65/17 is a popular swamper size that's about as big as you'll get on the van without (much) rubbing.
Swapping to this from a standard 215/60/17 tyre will lift the van 30mm anyway without the need for a lift kit. However, be warned as the speedo will under read and the larger diameter will essentially lower the gearing , making the van slower to accelerate and labour more under load.
Also, what do you mean by "body lift"? It's a monocoque, not body on frame.
