Bowler wheels
cossie
As above anyone fitted a set like the look of them plus obvs weight rated etc, guessing I’d need spacers? What’s the score with defender wheels??
Original defender or new pretender!? :D
The older defender wheels wouldn't be ideal as they're 5 x 165 pcd, so would need adapters. As they're lower offset than a typical t6 wheel, once an adapter is fitted, they'd probably hang out of the arch a fair amount!
As for L663 defender, they use 5 x 120 so that works. Offset isn't too extreme either.....
Load rating is 1250kg for each version so you're fine there.
Cheers @foggy3061 this is is off their website:
Tyre sizes 255-285
Specification
Diameter – 20″
Width – 8.5J
Offset – 41.5
Weight – 16.5kg
Tyre sizes 255-285
Specification
Diameter – 20″
Width – 8.5J
Offset – 41.5
Weight – 16.5kg
Looking at their site and the wheel size it seems it's the new defender L663 fitment you're looking at.
The specs look fine for a transporter but you will probably need spigot rings and defender wheel bolts in order to fit them.
This is what I thought. Thought they look something a bit different than what’s out there.
@BognorMotors do you have anything similar?
