Bulb warning after fitting THQ lights
Hi there (first time poster and owner and I promise I’ll get pics up in the right thread once I’ve cleaned her up real nice)
Mines got the V3s fitted and I get a warning light (sometimes straight away, sometimes after some driving) - am I right in reading all of this someone with VCDS(?) would be able to turn the monitoring off?
Hi bud , that’s what I ended up getting done , monitoring turned off although I’m pretty certain it was some dodgy led fog lamps the body shop put back in after it got hit , if it’s a dodgy bulb it doesn’t always show on vcds , trial and error , mine showed light on dash but didn’t say what it was or that there was even an issue , but vcds should get your problem gone
Great. Thank you. Is there a link to find someone with vcds?
Hi
I get a bulb out warning even though I changed both front headlight bulb recently. But if I turn the Caravelle engine off with the light switch on and start it again the bulb out warning is off.
Would appreciate any advice. Thanks
Hi
Have you changed them to upgraded LED bulbs in place of the original halogen ones?
