I was thinking more along trying a couple of these
The prewired means they are quite physically long but they are quick and simple to experiment with
Probably what I'd try is some high density 120 per m LED strip - the 12v stuff you can cut every 3 LED as that's a 12v segment of 3 chips 1 resistor - that should be around 3 cm with wires.
The downside is you probably have to buy a metre of it and I have to warn you soldering to the tape is a pig. The best advise is to not try and use all the tape, sacrifice the next segment by cutting just beyond the pads rather than across the middle to give a big as pad as possible. Use quality solder and an additional no clean liquid flux and tin the wires well beforehand. A bit of heatshrink to finish off and secure the wires, or maybe hot glue in place. You can get clamp on connectors, but if you are trying to tuck into a small light you don't have the space.
Red 3mm Prewired Diffused LED 20cm Cable 12V
Red 3mm LED featuring a colour diffused lens, prewired with a resistor and 20cm of cable. The LED features a low power consumption and is suitable for a wide range of 12V indication and illumination applications. Colour diffused lens Input voltage: 9-12V Forward current: 25mA 20cm cable Long...
www.switchelectronics.co.uk
12V/5M Ultra Bright 600 LED Light Strip Sticky Tape SMD 2835 120LED/m 8mm *FAST* | eBay
Smartlight™ 5M/600 LED LED Strip Lights (SMD 2835) - INDOOR & WATERPROOF. The LED's can be wired directly in to any 12v source or be connected to an AC adaptor using a DC Converter Cable. The DC Converter is included but the AC Adaptor is not.
www.ebay.co.uk
