Hello
I am planning on running the EHU cable and the B-2-B cable from the engine bay through the grommet in the bulkhead. I would then like to use the cable run that is on the left hand side of the drivers footwell. I have looked at the instructions about lifting the rubber floor and can see the channel I want to get to. How do I overcome the black plastic part that is on the floor under the gearstcik. It looks like cables comes out from under that. Is it easy tofeed cables around the back of the black plastic part so they appear in the 'cable tray' towards the drivers seat?
Or is it better to follow the run to under the passenger seat then across to the driver seat area?
I hope you can help
Phil
I hope you can help
Phil
