Thats either a massive pan or Quails eggs, cherry tomatoes and cocktail sausages.Love my cadac. You can’t beat a full English in the paella pan.
Either way, I want to park next to you.
Today’s top tip. Like it.No problem.
A little tip when you are set up, especially with the longer pieces of hose - when packing away/disconnecting, try and keep the open/male end high as you coil the hoses before connecting the ends together to trap as much of the gas as you can and always connect the open end first (the other end is self sealing on disconnect) - it's surprising how long it can take to get gas through 5 metres of hose.
There is 3 of us and we have managed with the Grillogas for the last few years. However, there have been times when a larger one would have been better so we have recently upgraded to the larger Carri Chef 2. When packed up there is not that much difference in size.What size Cadac do people suggest for a family of 3 occasionally cooking for an extra child. We have a job in the van for boiling potatoes etc and LPG point fitted at the rear.
So will be using as BBQ\ hot plate \ oven.
I want it small so we don't have to use up room when it's packed down but I'm not wanting to cook in shifts and spend all night over the grill.
I use the chef pan the most followed by the pot stand. We also use the paella pan quite a lot (some people don't bother with the chef pan and use the paella pan but the problem with that is you can't use the lid with it). Bought the pizza stone but so far had mixed results - it might be OK with a ready made pizza but I like to make my own dough, etc. - the dough tends to burn before cooked properly - will stick with it though.Thanks
Just the advice I was after.
What extra do people actually use. I will use it as an BBQ mostly but also an oven and generally cooking outside.
We tend to use semolina and/or polenta to coat cooking surface and on the pizza peels to aid release. Your pizza stones will be fine - I used to have a couple that were well seasoned as you describe but gave them away when I built a wood burning pizza oven, complete with terracotta tile cooking base, in the garden - cooks pizza in about 90 seconds - that is now redundant though and targeted for demolition as the dome is cracked and I prefer using my big green egg now.Cheers
The web sites are a bit naff for working out what comes with the set up as a standard and what each thing is used for. Anyone got a good link as the Cadac page isn't great.m
To start off I think need chef pan, flat hot plate type thing and some griddle type plate that the fat can drain through
What's a braai pan?
Anyone tried roasting a whole chicken as the photos? That seems ambitious to get it warm enough?
I have ceramic pizza stones for the house already as we do our own dough. So I'll try those first. They get better with age as they get seasoned absorbing oils etc. They are now a very dark brown almost black and you can feel how smooth they are now to the open porous surface when new. Water just runs off. They are now very hydrophobic. When using them at home I've always put a liberal coating of flour on the stone before adding the the dough as well. All this seems helps them not stick and cooks the dough slower.
You might want to try using them at home a bit more to see if they can becomes seasoned quicker. You could even try rubbing with oil and cooking them on a low heat without a pizza. I suspect the Cadac has a more direct bottom heat than the oven at home so I can see why they might stick eespecially if newer stone is used.
Use 00 all the time for pizza.I've tried polenta and semolina even a little bit in the dough and it gets too crispy. Normal finely ground pizza flour works well for us.
Cheers for the Safari link but I'm after the grill chef 2.....
With a chef pan and a couple of griddle hot plate affairs.
Got to love a mega fry up.
Tapas bowls!! this thing has more extras than a BMW!
Remind me why have I got a 2 ring hob in my van?!
Yep, it’s fabI only use the 2 cook now,
