I've had a squeaky squeal noise from the front of the engine for the past couple of weeks. Defo a dry ball race type of squeak. It has to be the aux belt or cambelt. I did suspect the latter as aux tensioner was done under recall a few years ago.
The forecast rain never appeared today so it took about 45 mins to get to here. Undertray off, air filter and housing out of the way. Aux belt off;
Squeak still there. The cambelt is coming out. New aux belt too I think. Neither of the belts looks too bad. A fair amount of rubber dust inside the cover though and the cords are visible on the cambelt teeth. Not a bad thing in itself, just shows it's a bit worn. This shot shows it's stretched a bit too, if the tensioner was set correctly when it was installed.
Another 45 mins or so to get it timed up, marked up and the cambelt off and idlers out. I always mark cambelts and pulleys. Can 't possibly get it wrong then on a reinstall;
I've finally put some blue paper cloth in the inlet in case I drop anything...
All out.
The larger idler pully has quite a bit of play in it, as does the tensioner. No play in the water pump and no leaks.
Off to TPS in the morning for bits. Not inclined to change the water pump at the moment. I may regret that in 24 hours....
The locking pins were stiff to get in and needed jiggling to fit, so I suspect the belt has stretched a bit in 5+ years and 40K or so miles.
